daryl506
- Jun 2, 2010
how much grease should i use in my front clutch? think i had to much in it and was making a mess. its a 2007 kodiak 450cc irs.
thx
thx
You want specifics or do you want to know how I do mine?
daryl506
- Jun 2, 2010
clutch grease
both would be helpfull thx i've heard so many diffrent things not sure what to do.
I don't measure out the amount of grease. I coat each roller with a liberal amount and then each groove and end with an even coating.
http://www.totallyamaha.com/atvs/tech/c ... Clutch.htm
With the centrifugal force it will all fly to the outside any way so just make sure the roller and the path has some.
daryl506
- Jun 2, 2010
well i used a level tablespoon in each pocket then smeered some on the rollers. stll looks like alot and like you said it is just going to fly out making a mess. and what about the back should it stay dry or a light coat in the contact points? thx for the help much appreciated. im a sled guy atv clutches with greese is new to me.
Seems a bit excessive but I would grease rollers, ramps and any place they sled with a lite film.
daryl506
- Jun 2, 2010
and what about the secondary clutch same stuff or somrthing else?to me if i use greese on it its just going to get on the belt.
daryl506 said:and what about the secondary clutch same stuff or somrthing else?to me if i use greese on it its just going to get on the belt.
No grease on Secondary.... just keep that clean of gunk and belts dust.
