Clutch Heat?
I got to thinking today at work, do any of you guys think that the clutchs might have a issue with overheating do to the closed side panel? I know that the skidoo revs have had issues a lot. I have some aftermarket air vent ducts that SLP makes that I might install in the cover, very easy to do, done many on revs and helped a lot didn't burnup a lot of belts.
Being a mountain rider I worried about this too. I'm gonna order some of SLP's flow-rites and install them on the front and back sides of that clutch side bellypan.
Hopefully that will let cold air in the front and hot air out the back.
Unless you have your clutching way out of whack it shouldn't be a problem.
