hartattack
I have an 2007 apex gt. When i release the throttle and the clutch disengages it makes a noise like the sheaves banging together, it not but thats what it sounds like. Is it a possible its a bad bushing? Any help would be great.
yox185
Normal, they do that from day one, brand new.
gotta-b-blue
noise
It could be a couple things. If your bushing gets too sloppy, worn out primary spring, I have seen weights wear, or dish, in one spot from ridding a continuous speed. How many miles on the clutch.
hartattack
5000 miles
gotta-b-blue
It doesn't seem like it would happen at 5,000 miles, but it would be worth taking the clutch cover off and checking things out.
- Sauk Prairie, WI
- www.ty4stroke.com
Clutch noise is very normal in these sleds. As long as your RPMs havent changed. I wouldnt worry to much. As always, you should be cleaning and replacing any worn parts in the off season.
