mx1500
ive looked on google and such but cant find any nytro part numbers for the primary clutch. i need to know what parts are interchangeable from a 1997 yamaha MM600. i have the clutch on my nytro now from the MM. it engages at about 5000rpm now. im trying to go the cheap rout first because all the parts for my busted clutch are around 800$. i need one stock weight as it got shattered.do you think all ide need is different weights and rollers?
radianguy
- Jan 1, 2007
Check out the parts catalog on yamaha-motor.ca or Ronnie's microfiche
Can't get the link to parts page to work
Mtnviper
- Aug 19, 2003
- Burlington Wa.
- fourstrokesolutionsllc.com
The spider is different between the two. The Nytro spider is slotted to allow proper clearance with the four stroke weight profiles as it moves across the roller.
You can use the MM clutch, but you either need to stick with weights designed to fit the 2 stroke clutches.
Or if you have access to a spider removal tool ("grunt tool") I believe that you can install the latter style 4 stroke spider in an earlier clutch.
There are LOTS of different weight profiles aviliable for the 2 stroke clutches, so you may be able to find one that works. Most likely it will require a fair amount of tuning time to get the shift out your looking for though.
Bill
Bill
Ffbsy
clutch
when i machined my sheeves I did not what to do it to my good nytro ones right away so I did it with a clutch off a viper and then just used my spider instead and then I could use my stock weights. But think I will be throwing some vmax 4 weights in anyway, I think them will pull awesome in a nytro.
- 6K
