FloridaBoy22
Loctite 290 is what you are after. Or any brand of bearing mount.
Here is the stuffRX1MPete said:X2 Dexta. What is this stuff and how did you do it? I am assuming you removed the end cover and stub shaft assembly. Big job or not?
OTM
Dimebag said:Beenba,
Did you get a answer from kimoajaj regarding this?
Don`t you believe in the result that i say,it is success?? This work and the Green whurt lagerlås is the stuff to use.But you are welcome to try something else than lagerlåsen.kimoajaj said:Looking forward to hearing about the result!
I`m considering doing it if it`s a success.
I did have some concerns about the axial play of the crank since there isnt any thrust bearings but when I think of the construction of the stub shaft, I realize that the forces from the clutch will never cause axial pressure on the crank because of the bearing in the stub shaft assembly. The Shaft movement is determined by the "slack" in the bearing so in other words the shaft wount move inwards against the crank.
So it should be safe!
The shaft assembly might be tricky to get out so leaving the primary on might give you some more leverage when pulling it out?
Basically it doesnt have to come off as long as you can reach the two outer screws on the crankcase.
Loctite has so many products but at work we have some Loctite 638 and the lathe guy always use this to make things stick, it said "axle retainer" on the bottle.
Could this work ? I guess.. . Hm
