Slayer
- Apr 11, 2017
- North
- 2018 Sidewinder MTX LE 163, 2000 SRX, 2004 RX1
Hello, I am wondering if someone could get me into the right direction for a snow drags clutching set up on my 2001 srx triple?
RobX-1
- Coldwater, OH
You will have better luck posting on the two-stroke side of TY.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
8bu-00
W-w-w primary spring
51-43
Green secondary spring
51-43
Slayer
- Apr 11, 2017
- North
Thanks for your input DMCTurbo, most appreciated. Do you or did you run this set up on an srx in the past?
DMCTurbo
- Nov 12, 2005
Yup. It's been 20 yrs.Thanks for your input DMCTurbo, most appreciated. Do you or did you run this set up on an srx in the past?
Slayer
- Apr 11, 2017
- North
Ok wonderful.
I suppose you had very good success with it.
Just to give you some more input to figure out if it will work for me as well:
We can't use studs in the Yukon or northern BC on the drag races. I am about 240 lbs clothed up, 6 foot 2. Elevations we run the drags is usually about 2500.
- 6K
