DAGE
- Nov 8, 2005
- where the snows at
- Other
- 06 Attak
I know I spend hours on the site looking up a good setup for my sled so I figured I'd post what I've used in the past, everything is setup for an 06 Attak, no real mods except 4 bullseyes in the airbox lid, CO settings are at 13 and it's stretched to a 144" with a cobra track
heavy hitter weights
short and long set screws in the heel
small bolt with thick and thin washers in mid
large bolt with 2 thin washers in the tip
oso primary spring
white sec. spring at 3-3
stock helix
it's been a couple years since I ran this setup but if I remember right it engaged at 4300-4500rpm, went up to 10200rpm and settled at 10700, it had good low and mid power but didn't have good top end, I think it died out at 115mph on the speedo
drag n fly's weights
4 washers and screw in heel
steel bolt with washer in mid
short bolt with washer in O/D
long bolt with 2 washers in tip
HC black spring
white sec. spring at 7-1
stock helix
it engaged at 4400rpm would climb to 10200 and settle around 10800, it was strong all the way threw the shift and I seen a max speed of 121mph on the speedo
HC 2 speeds
short bolt with 2 washers in heel
mid empty
aluminium bolt in tip (0.9g, came with the heavy hitters)
HC black spring
stock helix
it engaged at 4800-5000rpm and would go to 10200 and settle around 10700, low end suffers from track spin but the mid range and top end are good, I was able to see 119mph on the speedo
I don't have buddies that are into clutching and racing so I don't know if these setups are the best out there however the setup with the HC 2 speeds I was able to race my buddies '12 Apex XTX, he'd take me out of the hole by 3-4 sled lengths because I'd be spinning, once we hit 70mph I'd start reeling him in, by 115mph I'd be 4-5 sled lengths in front of him, I don't think his sled is fully broken in yet so the outcome might change once he gets more mileage on it
hope this helps some guys out
Kyle
oso primary spring
stock helix
HC black spring
stock helix
HC 2 speeds
mid empty
HC black spring
stock helix
Kyle
DAGE
- Nov 8, 2005
- Other
- 06 Attak
FYI I was wrong with the engagement of the black HC spring, it was engaging at 5100-5200rpm
I installed the short OPO spring into the primary and didn't change anything else, it engages at 2900-3000rpm and seems to pull as hard as the HC black, out of the hole it shoots to 10500-10600 and at full shift it's at 10400-10500, my max speed was 124mph on the speedo
I wish my buddy was out that way I could see what kind of a difference the spring made but once I readjust the weights I'm going to give him a call
