clutch tool and gearing
morg
NorthWestern Ontario
Ok. Here's another newbie question. What tool do I need to pull my primary clutch. Or I guess a better question is where is the best place to buy the puller and other tools. Or will my press from my doo or polaris work?
Also I'm running the stock rtx gearing, I think that's a 23 top, with my extended 144". Is that correct?
Thanks for any help
royal distrubuting has the pullers. do not use any other brand eg. doo or poo, wrong pullers. gearing should be fine. where abouts in nwt ont. are you?
Thanks. Ill order a puller today. Will my press work? Or do I need to worry about pulling them apart?
Thanks again
you can take the primary apart with a 10mm wrench to remove cover to change weights or springs. it can also be removed while still on sled but is harder to work on. there is minimal pressure on the cover from the spring and can be held by hand when removing the bolts.
24 will probably be too tall with a 144" track. Just my opinion.
I'm thinking you're right. But we have loooong lake runs here to stretch her out. Un the spring I might try it.
