ive checked everything,added 2 shims to each bolt and clucthes are fully closed"meaning sheaves touch on the inside".....now when i put my belt on the clucthes wont close all the way,ive blurped the gas and let it coast to a stop and belt still sits down in secondary...ive grinded off the casting on the inside also,clucthes close when belt is off,stay open when belt is on....please some info....
NY_Nytro
- Dec 24, 2004
- Grand Island, NY
- www.gi-snowmobiler.com
You got to put some load on the track, just coasting the track on a stand usually won't force the belt up. My Warrior does the same thing.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Are you "preloading" the spring properly when putting the secondary back together?
zquick1
How many turns to"properly preload the spring"
NY_Nytro
- Dec 24, 2004
- Grand Island, NY
zquick1 said:How many turns to"properly preload the spring"
It's about a half turn.
zquick1
What would happen if i changed the hole its in.I got it in the number 6 hole
yes the spring is preloaded,put it in by #1,dunno if thats where it was but its a half turn......
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
I don't know with regards to an RTX, but on my Vector, stock setting is 60 degrees, so the springs are in position 3 on sheave side and position 3 on helix side... (3+3)X10=60 degrees. Turn the helix clockwise until bolts line up.
some are telling me to put spring in #1 hole on secondary sheave and some say #3 hole,which is it....please some info
i have the rtx
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Well if you move the spring to the #3 from the #1 hole, you'll definately increase spring pressure in the secondary, which will cause the sheaves to close with more force.
Like I said, I don't know what the stock setting is, but perhaps do a search in the forum. I'm sure someone knows what it is.
zquick1
Stock is #6 hole on rtx
