I have just installed a MCX-turbokit on my Vector mtn -05, the clutch is still stock, what things do I need to change to make it work well with the turbo? Anyone with this setup that can give me some input maybe?
/Daniel
/Daniel
Turk
Tech Advisor
Need way more input from you before you get any help.
How much boost?
What altitude?
Your gonna need more primary weight(aftermarket) & a steeper helix for sure.
How much boost?
What altitude?
Turk said:Need way more input from you before you get any help.
How much boost?
What altitude?
I am running around 15psi, altitude I dont know really, the sled is stock other than the mcx kit. I have heard a 51 degree helix would work well, but I need more info on the other parts, any help is appreciated.
Turk
Tech Advisor
Altitude makes a huge differnce. can,t help unless your altitude is known as it can mean a 10 gram difference in the amount of primary weight.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
jde - put your location in your user profile (site regulations) then it's easier to help you out.
rxrider
TY Management
rxrider
TY Management
rxrider said:jde - put your location in your user profile (site regulations) then it's easier to help you out.
rxrider
TY Management
Ok, I am from Sweden, neighbour=)
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
OK - and thanks
TBird
- Dec 25, 2004
- North of Sweden
- Sweden
- Yamaha Viper and Yamaha Nypex
jde said:rxrider said:jde - put your location in your user profile (site regulations) then it's easier to help you out.
rxrider
TY Management
Why not check with MCX?
I also know Turk have worked with Vector turbo, now when he know you are a flatlander!
They know what work, but there are as anything else many diffrent setup's that works pretty good, it's just how much money you want to spend.
Just heavier weights, or adjustable weights?
Steeper helix, or adjustable helix?
Trail driving: x %?
Boondocking: x %?
51° helix might work pretty good for you, but i run 48° because i want better throttle response and boondock >90%.
Yamaha white secondary spring @ 60° or Arctic green @ 10° grab the belt for you.
Regarding weights, check with Turk or MCX, the ones you have might suite you, just load them heavy.
You might want a little higher engagement, you have Grn-Wh-Grn now, Yamaha have a Blue-Brown-Blue with higher engagement and softer final force.
TBird said:jde said:rxrider said:jde - put your location in your user profile (site regulations) then it's easier to help you out.
rxrider
TY Management
Trail driving: x %?
Boondocking: x %?
Thanks for the info Jan! I was planning to hear with marklund@mcx too, but I was also interested to hear from people on this forum, that have the same machine/setup.
TBird
- Dec 25, 2004
- North of Sweden
- Sweden
Forgot to say, enjoy boost, it's addictive!
Maybe we meet someday somewhere, i drive all over North of Sweden, selldom see other snowmobiles tho, me and my friends drive alot on untouched snow, it's strange how much less sledders thats out there nowadays,
How much boost?
What altitude?
Turk,
could you give me some more input now that you know I am a flatlander? =) I dont want to spend too much money, do you think it is enough with heavier rivets and a steeper helix? Maybe you have part.no? would be great in that case.
