Bop
Hello all. I have a 2003 RX-1 and need some opinions on clutching. My local Yammy dealer is suggesting a Dalton clutch replacement but a friend is saying to just replace the spring. Does anyone have experience on this topic?
Turk
Tech Advisor
Search rx-1 clutching & you should be done reading till the 09 sledding season. Sorry & your obviousely a new guy on this site but this topic has been covered about 1,234,347 times.
Bop
I have should have done that before posting, I'm new to this site but not new to all sites. I thought of it as soon as I posted. Thanks.
does someone have a link to black John's setup? I tested this setup back to back with the stock one and picked up 4 mph on a gun! Great setup for little money. Off hand I THINK its o-s-o spring, 14.5 mm rollers, 5\16" washers spacing the helix, 137.5 mains, needles dropped one position. Am I close?
Black 1000
I believe thats very close
Bop
After reading the past posts on this topic, I still cannot figure out what will work. There is so much info on here I can't seem to decipher. Will a spring alone give me any advantage? If so, which one should I use.
Bob Miller
- Apr 19, 2003
- New Milford CT
- Present Sled: 2011 Yamaha Apex 128
Here's my set up on my 04 Warrior
Primary Clutch: OSO spring, 14.5 mm rollers
Secondary Clutch: Silver Spring @70 degrees, shimmed with 5/16 lock washers.
Engine: 4 TPI valves with 160 main jets, Green Holtzman Springs, NGK CR10EK Spark Plugs
Track: SLP anti-wear pads.
This is a very inexpesive set up for the performance gain that you get
Jack_Shaft
Bob Miller said:Here's my set up on my 04 Warrior
This is a very inexpesive set up for the performance gain that you get![]()
Bob, what gearing are you running?
Bob Miller
- Apr 19, 2003
- New Milford CT
I'm running stock gears!
Tf18
warrior
Just curious, with this setup what kind of performance gains have you seen. I need to upgrade my 05 warrior with some mods this summer and would love to gain 3-5 sleds in 1000' if possible. Thanks for the info.
Bob Miller
- Apr 19, 2003
- New Milford CT
I run right alongside my buddy's 06 Mach Z up to 100 MPH and then he gains mere inches. I also run close to even with the new Apex.
Jack_Shaft
You're still running stock weights too, Bob?
Bob Miller
- Apr 19, 2003
- New Milford CT
Jack_Shaft said:You're still running stock weights too, Bob?
Yes! But I lightened the outer by drilling larger holes in the rivets!
I'm going to put back the stock 15.6mm rollers to bring the RPM up to try that! I'll be going back to Quebec the week of Feb 19th.
