ride -4-fun
anybody know what fx nytro code 12 would be ?? its popping a 10 amp fuse by the oil tank.... cant seem to figure out why it is doing this. owners manual say its a space but its not,has power to it .put a new fuse in and its fine till i try to start ... thanks
skidooboy
crankshaft position sensor fault code.
no normal signal from the crankshaft postion sensor.
open or short in wire harness
defective crankshaft postion sensor
malfunction in pick up rotor (primary sheeve drive shaft assembly)
malfunction in ecu
improperly installed crankshaft position sensor
that was all the manual had on it. it does not have diagnostic code for further troubleshooting or diagnostics. sorry i am not more help. ski
malfunction in ecu
NB-NYTRO
sounds like a bad sensor or a poorly plugged in one.
ride -4-fun
thanks ski for the info , now i need to figure out why its doing this .
Code 12 is for crank sensor. The 10A fuse in the starter relay is for the FI system which includes the crank sensor circuit.
If you're blowing fuses check the wires between the crank sensor and the harness. The sensor is mounted on the back of the cases behind the primary clutch.
Have you R+Red any parts that could have pinched or melted a wire? Have you wired anything in to the harness like heated face shield?
ride -4-fun
no i have not wired anything into those wires,all ive done is tether , temp gauge and i did it like allen said to .i'm not sure why this happen,and of course we got some snow today ..... its going to the dealer
Just some friendly advice, I'd recommend you disconnect your tether and temp gauge and see if your problems go away before you go see your dealer. Otherwise you could end up paying the dealer to fix a non-stock wiring issue.
Good luck.
Good luck.
ride -4-fun
i didnt even have the temp gauge wired yet, and it did run with the tether done .i tried the tether when i was done and it worked like it was supose to .i did the tether first then about a week later i started the temp install.calling dealer tommorow
