ProstockBenji
- Feb 24, 2005
- Leamington, Ontario
- www.doublediamondacres.com
A friend of mine has a 06 Attak with MPI stage 1 and was running in the trail on the weekend when his sled all of a sudden died and wouldnt start , it flash's code 15 , 20 but doesnt start . any ideas ?
Benji
Benji
15 is almost always there (throttle plates can't close fast enough with boost) ... 20 is a Baro sensor malfunction ... The one and only time mine wouldn't start was caused by water in the electrical connectors ... I now use silicone dielectric compound on every connector under the hood.
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
All boosted mpi's will show code 15 (and flash warning light ) , until you start the engine , then it will go away ! ( every time! )
Code 20 ???
Code 20 ???
ProstockBenji
- Feb 24, 2005
Hammer , water in which electrical connectors ?
I would start with the ECU in the nose and the fuel controller connections ... I also used a mountain bike inner tube to make a little rain coat for the ECU ... keeps the melting snow/water off the intercooler from pouring into the connector ... it was easier than relocating the ECU.
ProstockBenji
- Feb 24, 2005
Hammer , I talked with my friend Dave , he's going to check the connections out tonight . Thanks for the info .
Benji
Benji
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
- None, looking now!
I get 20 once in awhile. All I do is disconnect the fuel controller, plug the harness in stock. ( Bypass the controller ) Start the sled, turn the sled off, and re-connect the fuel controller and the 20 is gone.
I'll flash both those codes, but my sled still starts and runs. I wonder if there is something else going on there.
Four fouled plugs will also cause a no start condition ... Did that once but it was self inflicted no fault of the sled ... Does the fuel pump buzz when you turn the key on ??? … All you need is fuel, compression, and a spark to make noise.
