Code 43
slast
Kanata, Ontario
Recently my 2007 Phazer FX left me stranded on the trail yet again. After stopping for a short break, I tried to start the sled. It started and then stalled 5 seconds later. Code 43 was flashing in the pod and the sled would no longer turn over. I also no longer heard the fuel pump running. I'm told that it could be a faulty pump relay but I swapped them out and still nothing. Should the sled still turn over even with a faulty pump? I wonder if I'm chasing 2 different problems.
Any suggestions? Anyone else have this problem?
See my notes in the Defective Fuel Pump thread. The issue turned out to be a bad ground on the wiring harness.
Cheers!
