trnthecomptinblue
What does this code mean? Thanks
Swiss Sledder
T.O.R.S. or Throttle Over Ride System. For details on error codes at link below.
http://www.ty4stroke.com/viewtopic.php?t=36172
You're throttle cable is most likely causing the problem. If you do a site search on TORS, you will find lots of info on how to resolve.
trnthecomptinblue
Thank you for the fast reply....
RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
Are the error codes the same for the RS series as the Apex???? I see at least the code 84 is the same..
