code p1339? Help on side of trail
billbies
Grand Rapids, MI
Just had this code come up on me while riding today code p1339.
what is it and where is a code list to reference in the future if needed
Thanks Ill sit here in the field til I get an answer and enjoy the outdoors
just looking thru manual and saw crank sensor tooth missed
What the hell is that started sled back up and its gone but what would cause that
Many of us hacve seen it P1338 & P1339 are crank spike and gear readings - we think it is an over sensitive ECU losing track of the crank censor if you sping the track and over-rev by a hair. It has happened 2 times on mine with the turbo it happens so fast you cannot catch it. Just shut off and codes clear.
Mine has only given me that code with the hot start problem. Thought I had it fixed with the vent tube modification but no such luck! Just did it again. I normally only get the 1338 but 1339 has come up if it's being really stubborn.
