Your pic is blurry but I assume its burnt.Yes I believe all of them are grounds.You could check with a Ohm meter.But you should get this fixed correctly.
S2009-008 its a technical bulletin so it doesnt get fixed unless its a issue.They remove 2 of the grounds and route them directly to the battery negative.
07Nytro
- Dec 8, 2007
- Winnipeg, Mb
- None right now
Hmmm. I really want to ride this weekend but when you take it in for this kinda work, this is free right?
Jeremy
you betchya, it cost me 13 bucks but that was because i was missing some of those cheap allen key twisty thingys holding my side cover on !!!
07Nytro
- Dec 8, 2007
- Winnipeg, Mb
- None right now
wheres the bulliten! Can I read it?
check your PM's.
07Nytro
- Dec 8, 2007
- Winnipeg, Mb
- None right now
Thank you guys for the help. Problem fixed and I was out riding. I bought the update kit. $5. Easy to install.
