Code P0563
VIPER85
Lisbon Falls Me
2017 Sidewinder XTX LE
2008 Nytro RTX SE
2008 Phazer RTX
Put another 100 miles on my sled today bringing the total to about 900 now. Toward the end of the ride I noticed it flashing code P0563. The sled still ran perfect while moving and I didnt notice anything wrong until i tried to stop! The sled was idling at 3700 RPM causing the clutch to be slightly engaged. Called the dealer and they tell me this is a high voltage code. I will be bringing it in tomorrow and will update on their findings. Has anyone else had this issue?
I just got it back from the dealer. The P0563 is a high voltage code. they replaced the voltage regulator and the reverse actuator. They said it was putting out 19 volts when they tested it so they think that's what took out the reverse. So a new voltage regulator and new reverse actuator and im back in business.
