nytro rtx se
- Dec 2, 2008
- Cambridge-Bay,Nunavut,Canada.
- 09 fx nytro rtx se old sled
14 Sr. viper rtx mpi190 old sled
17 sidewinder 137 xtx 300 hurricane
Was out for a drive yesterday , did a pretty big jump and kind of a flat landing sled was fine. However when I shut sled off for a bit then go to start it, P-1692 was on and flashing R along with the beeping. Looked it up and was forward relay low circuit. Had me pretty bummed out for a bit. So I was a bit of a ways from home or access to tools to check under hood. I decided to lift one side ski up as high as I could with the ski loop and slammed sled back down, turned the key back on and damn that was enough to get code off and drive home with no problems. Should I take out fuses/relays and clean with electrical parts/contact cleaner then apply di-electric grease? Has this ever happened to anyone?
