Apex Man
Anyone tried the new Cometic .050" copper head gasket? This is within .001" of 3 factory gaskets stacked. Any problems with fluids not sealing or whatever else? O-rings in the block needed with the all copper gasket? I ordered me one to go with my supercgarger kit. I don't want to get into the motor but I'm scared of getting too low of octane fuel for my Apex, especially in Quebec. I would like to be on the safe side for once in my life time. I plan to run 7-10 lbs. of boost.
Thanks,
Moon
Thanks,
Moon
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
- None, looking now!
There's an idea. How much was this and from where did you order it? Let us know how this turns out for you. I would imagine, with one single gasket, maybe the torque specs are different than from 3 separate gaskets????
-Vince
-Vince
Need for Speed 2
torque it to ted jannettys spec they wont leak or blow out then also 50 +the gasket is over kill for7-10 i think.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
I would not use copper for fear of it not sealing. The factory gaskets are embosed for sealing. I also wouldnt take compresion away for 7-10 lbs on a blower w/92 octane fuel. Do tourqe the stock gasket down though to Teds specs.
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
- www.jannettyracing.com
Are you sure it is Copper?????
I would not use a Copper head gasket.
I would use a multi layer steel head gasket like Yamaha uses.
Cometic makes these in MLS also any thickness you like.
This is what we use in all our Turbo applications.
Copper is a very soft material and will not hold after several heat cycles.
I suggest just stacking 3 factory head gaskets which are 0.017 each giving you a total of 0.051 for 12 lbs. on pump fuel
Ted.
Ted.
Thomas800
- Dec 17, 2004
- Fort St. John B.C. Canada
- www.snowmobiledragsters.com
Do Not use copper head gaskets. We are using them in our drag race motors, oringed with .041" ss wire, and it is a ROYAL pain. You really don't want to go there unless you are over 40# boost, and even then I'm still not sure they are the answer. The embossed gaskets are definitley the way to go for any trail motor.
nothinbutansrx
- Jun 30, 2007
KnappAttack said:I would not use copper for fear of it not sealing. The factory gaskets are embosed for sealing. I also wouldnt take compresion away for 7-10 lbs on a blower w/92 octane fuel. Do tourqe the stock gasket down though to Teds specs.
I can understand his fear of octane. Where I ride up there you seldomly see anything higher than 89 octane and you know that a lot of the trail stops are marginal at best.
- 8K
