Foxhead
So i tore into my nytro tonite to replace the exhaust donuts. The original 3 donuts were shot, about half gone. The material on the heat shields is kind of burnt away, not totally but definitely not like it was. Should i be concerned about this before i throw it all back together? I don't want to be worried about something, especially being right under the gas tank. Hopefully I will never have to do this again, replaced with copper donuts from OFT Racing. They fit extremely well and I am very happy with their product!
AttakDog
As long as the donuts are good you should be OK. I found some aluminum with fiberglass mat in between heat shield and put on my old RX1 just in case. Header wrap with high temp red silicone would work too.
09nytro
You can get the heatshield from jegs that's what I did..
Nine2Nine
Half of mine has been missing for 2 years, keep in mind there is a layer stuck to your tank as well. Keeping air moving through there is key.
raginyamaha
get copper dougnuts and never worry about exhaust leaks again......
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
Moose racing has some material too.
09nytro
Don't be cheep..why not do it right ...keep the heat where its supposed too be....
