Converting Speedo
highonboost
Is there any little trick to convert the speedo from km/h to mph?, I know the one to turn the lights on with turning the sled on.
No need to try and find your manual. They are available on-line on the Yamaha web site. Here is the text from the manual for an 05 RX-1 Mountain.
To switch the speedometer, odometer, and tripmeter displays between kilometers and miles, select the odometer mode "ODO", and then push the select/reset button for at least 10 seconds while the snowmobile is stopped.
Yes just push and hold odometer reset button until it flashes and changes to one or the other.
