lyndske
there appears to be a coolant manifold located under the exhaust on the back side of the engine. I am hoping I can disconnect the exhaust and the rear engine mounts to allow the motor to tilt forward. I am hoping I do not have to remove the motor for this repair. My shop manual shows an o-ring on this manifold, I believe this is what needs to be changed. thanks for any advice
lyndske
found the leak
not enough room had to remove the motor. found the coolant hose pulled off from the manifold under the exhaust. reinstalled and tightened. 2005 rx1
