targabill
Hi All,
Has anybody added a coolant Temp gauge that they can see at all times?? Gauges, Links, How to, whatever!!
radianguy
- Jan 1, 2007
Koso temp gauge, works great!
Won't let me upload Pic.
![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
targabill
Thanks for the Koso gauge recommendation.. I looked at that link for a Phazer install..
On the Nytro the hottest coolant hose is the one that goes from the head to the bottom of the thermostat housing, under the throttle bodies.
If you use the input to the radiator it would be only coolant after the thermostat opens and it's only a portion of the coolant as some goes directly to the lower heat exchanger.
I will probably order on of these today, is the a *F version..
targabill
Where did you find a Koso with a 25mm adapter, I only see 22mm
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
I bought mine separately from the gauge. It was actually 26mm.
targabill
Ahh yes, there are more 26mm ones, the problem i'm having is the sensor is a 10mm x 1.0mm thread.. and all the adapters have 1/8 NPT thread. You wouldn't happen to have a link to a 26mm adapter with 10mm x 1.0 sensor thread would you?
And thanks again..
And thanks again..
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
I got the 1/8 NPT sensor. Check for a gauge on its own with the 1/8 NPT sensor. Mine was branded Keenso from Amazon Canada.
