cooling fan not working
Mills
Elk Mound, Wisconsin
'21 SRX, '14 Viper RTX, '06 Apex, '99 SX 600, '74 TL433F,
Ok the fuse is good. Fan relay is good (I tested it and dealership tested it). Fan motor runs when connected directly to battery so it is good. Only thing left to check is temp sensor and wiring but I dont know where the temp sensor is located and the dealership says there is a ground wire bus bar near the oil sump tank to check but I dont see that either. Any suggestions?
okay I did the code 51 check to make sure the relay in fan system were working all is working properly now. I think it may have been an issue with the connector at the relay.
Probably old style relay.
