Cooling fan
tedgoesfast
fredericton nb
Wired a toggle switch into fan relay on ground side so I can turn fan on early waiting to get out and see on hard trails with low lube to see if it will pull temp down should work great
Do you have a temp gauge? Let me know what it runs at. It’s a good idea. I thought about adding a resistor to make it kick on at 190 degrees vs 210 automatically to help give it a head start when coming in and out of towns. On the trail mine runs 160-170 on 12 psi of boost.
