GP292
- Mar 5, 2007
- Southern-Tier New York State
- 2016 RS Venture TF
Is there a difference between Yamaha V-Belts 8DN-17641-01-00 and 8DN-17641-00-00. I will be using this on my 2008 FX Nytro.
No difference, the 01 will replace the other in time.
The new 8DN belt is .015"-.020" wider
But I was also told the new belt will override the 00 version so it will not hurt anything to run either.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Yes, the new 01 belt is a superceeding number to the 00 belt! You can use either on the sled though and it will not damage anything!
BADSLED
- May 13, 2004
- Syracuse, NY
- 2025 Sidewinder XTX LE EPS
2012 Nytro MC Xpress 270
Srxspec said:Yes, the new 01 belt is a superceeding number to the 00 belt! You can use either on the sled though and it will not damage anything!
Is it true the -01 belt is wider???
- Apr 17, 2003
- Menno, SD
- Menno, SD
Yes somewhere around .020" wider than the 8DN-00 belt!
Actually the 8DN-01 belt is slightly narrower, about 0.4mm / .016", across the top surface only. The top outer edges get dressed to clean them up after they're made and it removes a little material. Otherwise same as the -00 belt and interchangeable.
Fasttoys
Never known you could write so much about a belt
- Apr 17, 2003
- Menno, SD
- Menno, SD
Brand new belts measure as follows.
8DN-17641-00
Top width: 1.358"
8DN-17641-01
Top width: 1.383"
8DN-17641-00
Top width: 1.358"
8DN-17641-01
Top width: 1.383"
