S pump
- Nov 19, 2005
Yah, I'm pretty stoked about having the warranty. I really have a good dealer too. New England Cycle in Hartfort, Ct. Sean has always taken pretty good care of me when it comes time for warranty work..............I probably have had 5 suspensions put in various sleds in the last ten years and never a question asked. I think Yamaha uses my sled as a test mule.................won't be long now boys.
S pump
- Nov 19, 2005
Yah, I guess I just wanted to tell the end of the story for anyone else who may have the same issues. Seems for 6k they coulda dropped a new motor, exhaust and skid in. I guess thats how the dealers stay in business...............Anyone have a Ripsaw for sale?Budweiser said:Sucks for you but at least you had the warrenty and they covered it. Thanks letting us know how it turned out!
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
- 18 sidewinder; 06 Apex RTX
We just had our club grassdrags, and the first thing we did was regrease the pto side driven pulley bearing, and the axle bearing (with a needle). Virtually clean grease came out, as it's so easy to do, we do it during the winter too. Last year I changed a track on my old 03 rx1 for the new owner, and I put a new bearing on, but the old one felt like new...who knows how long they can last if you grease them regularly.
S-Pump,
Did they happen to replace your aluminum suspension rails? Sorta sounds that way.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
SumpBuster said:We just had our club grassdrags, and the first thing we did was regrease the pto side driven pulley bearing, and the axle bearing (with a needle). Virtually clean grease came out, as it's so easy to do, we do it during the winter too. Last year I changed a track on my old 03 rx1 for the new owner, and I put a new bearing on, but the old one felt like new...who knows how long they can last if you grease them regularly.
the needle trick....what did you do drill a hole in the seal?
S pump
- Nov 19, 2005
No, they were fine but I did find a small crack in the suspension arm that they should have addressed when they put a new Ohlins in. I'll get it welded and move on.Doug said:S-Pump,
hayastusa
the needle trick....what did you do drill a hole in the seal?[/quote]
Carefully pop the seal off. It snaps right back on when you're done
