S pump
- Nov 19, 2005
I found a small crack in my w arm in the rear suspension, nothing more than a 3/4" stress crack..........Am I correct that the skid is ChromeMoly and should be weld using TIG? Second, does anyone know where I can find the part numbers for Ohlins springs. I had my shock replaced and I think they put a stock spring back on. I want to get it revalved again and want to make sure i have the fat guy spring before I send it out to Bruce at Pioneer.
Bruce will have the part numbers and as far as the w arm I know guys have welded them. Probably check the suspension section and search w arm.
