cracked exhaust
What are the symptoms? I had an awfull rattle on my 05 it turned out to be the gaskets at the crossover under the seat. take of your seat there are two rubber plugs on the tunnel these will give you access to two 12mm bolts on the clamps loosen these, there are two 10mm on the heat shield and four bolts and rubber mounts at each corner on the can, with all these out you can slide your exhaust out by pulling towards the rear of the sled, check your gaskets and replace if nessecary.
