Custom ECU for apex, what would you like?
1yamman1
Ontario, Canada
Hypothetically speaking if a custom ECU was developed for the Apex what features would you like to see.
few things come to mind:
-Fuel/timing adjustability
-knock sensor input(for auto timing compensation)
-A/F input (for closed loop mode)
-programmable inputs/outputs (for NO2, water/meth inj, etc)
-be able to display any value(water temp, A/F, boost pressure, etc) on stock speedo, along with adjusting fuel and timing maps on the fly.
-optional addon LCD display
-USB interface with data logging
What else???
more voltage to the warmers
-2 spare analog inputs with scale & offsetfor display
-scale value to map the dreammeter
-ASCII display of error codes
-logging in realtime to generic USB sticks
Read that alot here, I have an 06 ER and the grips will burn my hands off, its usually set at 2 or 3 bars and its plenty hot enough.
