Custom Tail lights
1CrazySledder
Cartersville, GA.
None, looking now!
Lets see 'em boys. I have extended my tunnel and have a gas rack on it. Now I need to find the baddest tail light or idea for tail lights.
Thanks...
-Vince
Vince,
Check out these guys: http://www.fourbarr.com/index.php
They will do custom work, I've used them in the past and they're usually pretty quick in filling a custom order. With your sled I'm sure that you should be able to come up with an awesome looking custom design.
Don
How about this !
VX1R said:
Vince,
Don
I checked out that site. I'm looking at two lights now from there. One mounted to my gas rack saying " BLOWNGT ", and I liked the other type they have where the lights are intergrated into the rear bumper. I may end up with both. lol
Hammer:
I liked what you did with your sled. My problem is with a gas can in the rack, that light won't be seen that well. I need something for the back of a gas rack. I have a few ideas, it will be a one of a kind set up, I promise.
-Vince
They can be mounted anywhere with the 3M adhesive tape that's already on them. Just peal and stick. Two seasons and tons of heat cycles later it’s still attached as strong as the day I installed it. Note that all LED lights are not created equal. These have a true 180* spectrum with 30-LEDs packed in there. These are SCREAMING BRITE! Even in direct sunlight. I'm 100% satisfied with the purchase.
this is the one i installed on my sled. the speed in the vid is too fast but gives the general idea.at idle the light does the knight rider thing then when the brake is activated it flashes bright 3 times then solid bright. its bright as hell also.just fabbed a piece of metal to rivet to the plastic and 3m taped it to the bracket the location can be seen with the spare gas cans on. http://www.customdynamics.com/videos/kn ... _video.htm
i might have to look into this stuff a little closer!
