ranger1
I noticed today my winder has something cycling when it is not running and the key is off . It cycles about every 10 seconds and runs for about 3 to 4 seconds. At first I thought it was the beer fridge ( in garage) but nope, it's coming from the sled, disconnected the battery to confirm. It hasn't run since yesterday. Is this normal, if not what could it be? Thanks!! Tried to upload a 5 second video but says file is to large
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
I'm guessing you are hearing the gas tank venting. The gas tank vent valve holds pressure till it gets warm enough and vents to atmosphere. As it warms it does this occasionally. Take the gas cap off when you hear it doing it and you'll see the pressure on the cap and the venting will quit.
ranger1
OMG, lol!! When I disconnect the battery the cycling type noise stopped but only momentarily,( coincidence) then started doing it again, haha!!! I just took the gas cap off , low and behold, the sound stopped, lol!! Well, thanks Mike for the easy fix.....I do however feel like an idiot, lol!I'm guessing you are hearing the gas tank venting. The gas tank vent valve holds pressure till it gets warm enough and vents to atmosphere. As it warms it does this occasionally. Take the gas cap off when you hear it doing it and you'll see the pressure on the cap and the venting will quit.
Yup...I took the diaphragm out of my vent valve when the sled was new as the squealing drove me crazy .
ranger1
So thats the fix Bob to get rid of that noise, remove the diaphragm from the vent valve? Ya it does it constantly, never seems to stop, letting the pressure out is only a temporary fix as minutes later it's back, lol!Yup...I took the diaphragm out of my vent valve when the sled was new as the squealing drove me crazy .
Thats what I did with mine as well as adding a vent from tank to up under the handle bar pad from the old tank fuel return fitting that was not being used after rerouting return line to over the fuel pump basket. I put a one way pressure fitting on both vent lines.So thats the fix Bob to get rid of that noise, remove the diaphragm from the vent valve? Ya it does it constantly, never seems to stop, letting the pressure out is only a temporary fix as minutes later it's back, lol!![]()
ranger1
Wow, good idea Bob!!! Thanks !Thats what I did with mine as well as adding a vent from tank to up under the handle bar pad from the old tank fuel return fitting that was not being used after rerouting return line to over the fuel pump basket. I put a one way pressure fitting on both vent lines.
Turboflash
- Mar 18, 2019
- Southern MN
Did you remove the vent fitting from tank to do that? How is it secured into tank?Thats what I did with mine as well as adding a vent from tank to up under the handle bar pad from the old tank fuel return fitting that was not being used after rerouting return line to over the fuel pump basket. I put a one way pressure fitting on both vent lines.
There are advantages to the stock setup such as fuel won't leak if the machine is partially on its side for working on and also fuel keeps better with the stock setup.
I did the vent mod when the sled was new in 2019 so I am going by memory.
The stock vent fitting is held in place with a grommet and so is the original tank fuel return fitting.
I just attached a fuel line on the return line fitting, installed a one way check valve in the line, and routed it up the steering post under the bar pad.
Overkill really.
Overkill really.
Turboflash
- Mar 18, 2019
- Southern MN
I thought you were referring to the actual tank vent where that clear line is connected to?I did the vent mod when the sled was new in 2019 so I am going by memory.
Overkill really.
stgdz
- Mar 27, 2021
- Buffalo MN
the sidewinder squeel!
