TT
What set of Dalton clutch weights for 12-16 psi @ sealevel to 2500feet - DTYA-2 79-86.4g ( most common for most boosted applications) or DTYA-3 84.6-92g (a new heavier base weight for higher boost applications)?
Or go for the DTYA-2 with the optional tungsten inserts?
TT
Any inputs?
BOOST-IT
- Feb 12, 2011
We run these weight in everything. Definately go with the Tungsten inserts though. I run 96 grams at 17 lbs at 6000-8000 ft. They are a great product. The profile is great, they have good OEM bushings, and they adjust in minutes right in the clutch.
TT
Thanks!
Adrenaline Addiction
I'd go with the DTYA-3's for sea level, I am running them fully loaded with the tungstens as well. 6000+ft
TT
Thanks!
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
Hello TT, going Dalton ay-ay
Well I do, except for clutchweights. Are you still riding?
TT
No I am not riding any more. I am rebuilding our cabin.
I am looking to try some weights that are fast and easy to clutch in the field if boost controller is beeing used. Super tip weights are working great, but too much of a hazzel to add weight will riding.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
I wanna go out riding a few more times, Ifjordfjellet are some 120-130 kms away, those trails are open until May 18.
We started rebuilding out house last autumn and we're going to continue as soon as riding is done.
Agree on the in-field adjustability, I ride one boost only and thus my STs are perfect for me. If I run out of meth, it's no fun anymore anyway until I refill and boost increases from 14 lbs (on the failsafe) to 22 lbs on meth
Talk to you later buddy
Jan-O
Jan-O
