Darty Warrior - Expert X
tonykof
Williams MN
Any idea's on how to help the dart in my Warrior? Alinment is good, I've been running C&A Razers & it was terribly darty, I just put tried a set of simmons this weekend & it helped but it's still a handfull..
Normally I'd try to take some pressure off the skis with the front of the skid but I can't do that with the expert x.
BTW I had both the Razers & the Simmons skis shimmed..
I'll probably end up running the Simmons (they were used so I need to order a new set of carbides.)
One of my other concerns is scrubbing top speed, I have no proof but the simmons seem like they would be slower...?
Are you rubber stoppers indented where the shim sits? Over time you will have to replace the rubber or add a thicker shim. When you site under the carbides on bare concrete is the front edge off the ground? It has to be to eliminate darting.
I have had both skis you have and the simmons did not reduce my top end.
Thanks for the input Kinger. I'll check to make sure the front edge is off the ground.
I also need to get new carbides for the Simmons, Any suggestions?
Tony
i also run the expert and c and a skis. like kinger said shim the rear rubber block till the carbides lift at the front.
You can also get a set of dually shaper bars if you dont want to reduce the ski preasure ;)!
