mikextx
- Feb 19, 2017
- holland MI
- 2017 apex xtx
- Holland MI
Somehow the battery tender on my 17 apex got unplugged, no idea how long. Battery was stone dead. I charged it on 10 amps for 15 minutes and it fired right up. My question is, now do I trust it? I don't need a dead battery out on the trail. Should I buy a new battery?
Charge the battery for a day or so with the battery tender on the lowest amp setting (1 or2 amps). Check battery voltage with a a meter. Unplug the tender for a week and then check the battery voltage with a meter again. If it drops down to 11v or lower the battery is most likely toast.
mikextx
- Feb 19, 2017
- holland MI
- 2017 apex xtx
- Holland MI
Alright, I will do that. Thanks for the reply
radianguy
- Jan 1, 2007
I'd fully charge the battery and get it load tested.
Mills
- Dec 4, 2007
- Elk Mound, Wisconsin
- '21 SRX, '14 Viper RTX, '06 Apex, '99 SX 600, '74 TL433F,
Any good auto repair shop will have a load tester. I am with Radianguy, charge it and get it load tested that is the only way to know its condition.
Snorunner
- Jul 17, 2018
- Deerwood
- 2016 Vector XTX
2017 Vector XTX
2001 Arctic Cat
Totally agree with the load test. There is another test it's old school maybe only applies to lead acid batteries and not glass Matt or AGM. It is called a sulphation test. If I remember right you apply a certain amount of amps and if the voltage goes above a certain value it's toast. Saves the tech from taking the time to charge it first. Of course that's from the Automotive world. Maybe not relevant in the Powersports world.
FrozenTows4
- Nov 6, 2014
- Brainerd Minnesota
- 2014 XF7000 Sold
2017 ZR6000RS
2018 ZR6000 El Tigre
2026 EXT858 Special
- YOUTUBE
- FrozenTows1
2017 Apex, built in 2016, with either a 2015 or 2016 battery. It's pushing 4 years old.
Batteries talk to us. We need to listen. Going dead in storage is saying it's time to go.
Can you pull start your Apex? Why chance it and wonder during our too short of a season if it's going to make it?
Get a new battery.
Get a new battery.
InRBigness
- Apr 10, 2014
- winnipeg, manitoba
I agree with FrozenTows4. Small expense for piece of mind. Otherwise, bring cables and a friend whenever you ride.
Also I noticed that you put it on a car charger at high amps for a period of time. I have been told that putting big amperage through these little batteries is a no no. Slow and steady is the way to go for longevity.
Mills
- Dec 4, 2007
I believe the Yamaha batteries have the charging instructions printed right on them for each amp range your charger has. When I replaced the battery in my Viper I used the Yamaha battery and followed the charging instructions on it. I had done the same 10amp long charge as MikeXTX did on my previous battery and fried it due to the length of time I had the 10amp charge going.
yamarider13
- Mar 9, 2014
- East Central Wi
- 2014 Vector LTX
2015 Venture GT
Optimate 3 or 4 is the best battery trickle charger that I know of for small batteries. I have even used them on car batteries. Many times it will bring it back to life and will shut off automatically when charged so it won't get over charged.
4strokes
- Mar 13, 2018
- charlemont ma
- 18 winder xtx 09 nytro xtx 06 apex gt
Only smart post in the whole lot. tired of this debate. If you like pull starting an apex, by all means dont buy a battery. If you want to recharge the old one so it starts right here and now, go that route.2017 Apex, built in 2016, with either a 2015 or 2016 battery. It's pushing 4 years old.
Get a new battery.
mikextx
- Feb 19, 2017
- holland MI
- 2017 apex xtx
- Holland MI
I will get it load tested. That's one thing that I'm not fond of with a 4 stroke, dead battery and your screwed.
RobX-1
- Coldwater, OH
That's why I invested in one of those portable NOCO chargers; a GB40.
mikextx
- Feb 19, 2017
- holland MI
- 2017 apex xtx
- Holland MI
That is a great idea!
