Defective Oil Tank Fitting on '07?
Mtn-Track
N.E. Colorado
The oil leak on the '07 RS Vector Mtn started to get a lot worse yesterday. I took off the right side panel and it looked like it was the hose on the bottom of the oil tank. After a closer look when it was running, it turns out to be the seam in the 90* fitting on the bottom of the oil tank. Right where they bent the 90* angle and 'fused' the joint, not the flange. It has not been hit, but seems to be a bad fusion of the joint. Anybody else seen this? :o|
i think some of the nytro guys are having similar problems. id do a search and ckeck it out.
