Difference between vector 07 & 08
poljeon
Hi
That is my third vector gt. I had a 06 a 07 and 08 .
My best was 07 . The problem with the 08 is taking more gaz than the 07
It goes a little slower on the top end
and I do 4000 miles with the belt compare of 9000 miles with the 07 belt.
I Check and see that the spring in the secondary clutch is the same .
But the spring in the primary clutch for 2008 is Yellow - silver - yellow.
the spring in the primary for 2007 is blue - green - blue
Do you know if it's enough to make the difference on eating belt and gaz.
Do you know what else is different in clutching or gear between these two years.
I checked the needle and jet needle and they are the same for both years.
Thanks for reply
Paul
Could be as simple as the '08 body work doesn't flow as much air to the belt as the '05-07 style.
Is the gearing lower on the '08?
