differences in MTX and XTX A-Arms
nickleuci
Where? NH
Do you guys know if there are any differences in the lower a-arms between the xtx and mtx models?
How about differences in the lowers from model year 08-13?
From what I can see in photos the lowers look like they have never changes. Looks the the spindles and uppers are different from 08 to 09.
I'm on the hunt for a RH lower that I bent, hence my questions, Yamaha PN from yr to yr, model to model differ.
MTX arms are shorter, PN is probably different because of color, the 08's had a different geometry as well
I'm pretty sure 10 and up the front end is the same for all of the nytros, the MTX's just don't have a sway bar.
The 09 RTX SE and XTX also have the same front end as the 10 and up sleds. Only differences are shock type, color, ball joints and subframe updates.
The MTX regardless of year has a narrow front V's the standard nitro wide front. A-Arms are different lengths. The MTX also does have a sway bar.
This only applies to 08 and 09 and 2010 non SE models.
2010 and up MTX have the same front end as the shorty 09 and up Nytros. However there is no sway bar but the attachment is still on the a arm. Just did this. Took my mtx arms off mine and put them on and XTX.
