canoehead said:If your constantly running Deep Pow then you should have no problem. But as for hard trail, I don't think it would be as good and in that senario more is better. And regardless you'll have to cut the rear axle sleeve, so no to running the stock set-up.nytroman20 said:Is it possible to remove the two outside wheels and put them between the rails with the stock setup? Or is that a special kit? And what are the advantages, if any, of only having two wheels between the rails?
That's exactly right, by narrowing your lateral axis allows you take a tighter line. In other words for example a Deep Vee hull on a boat can carve harder/tighter than a Tri hull style of boat. Hope this helps......nytroman20 said:Seams like it would boondocks side to side Boondocking with only two in the middle as the track will flex a bit more... Maybe I'm wrong but thats my first thought.
