YamahaFreak
The Pen is Blue
- Nov 26, 2009
- McHenry, IL
- Sr Viper XTX SE
I have a bender silencer on my nytro, does anyone recommend getting a power commander or do you think it will be fine?
Turk
Tech Advisor
You won,t know till you ride it. If it hesitates & pops a lot you need more fuel.
billymx815
- Nov 17, 2009
- S. Berwick, Maine
- SXV Venom, RTX Nytro, SR Viper RTX SE
- Maine
My thought would be if you just have the slip on Bender exhaust silencer you'll be ok. That changes if you put on a higher flow header or change your air-box (i.e. - K&N kit) then you'll need the PCIII or risk performance issues or worse engine failures...
nate007
- Dec 25, 2006
- Iowa City, Iowa
- 1. '06 Apex -twin screw
2. '04 Redline Revolt 800
3. '09 Nytro XTX - twin screw
I have the Bender on my sled, and with the bottom of the airbox horn removed, I was running lean at WOT. I did have to put the PCIII on it.
YamahaFreak
The Pen is Blue
- Nov 26, 2009
- McHenry, IL
- Sr Viper XTX SE
Alright thanks guys
