TOMBOB
- Jan 20, 2011
- Saranac,Michigan.
- 2006 APEX ER
been reading a lot about removing tunnel protectors. have 2006 vector
no studs, do you taken then off because of ice build up?
thanks for aNy help
TOMBOB
thanks for aNy help
TOMBOB
thrasher
- Nov 22, 2006
- Ottawa Valley, Ontario
- 06 Vector RS ER
Possibly due to ice build-up or them just becoming loose. I would not remove them because it would be time consuming to put them back on if you ever decided to stud or sell your sled, and most of the ice build-up is on the suspension itself anyhow. Just grab them with your hand to see if they are loose or the rivets are broken. If not, leave them there.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
If your not running studs take them out. With out studs there is no need for them to be there, gives you more room for a taller track. Save 20 or more pounds of ice with out them.
TOMBOB
- Jan 20, 2011
- Saranac,Michigan.
- 2006 APEX ER
do i need tunnel protectors
thanks apex06 to late this year the sleds ready to rock&roll
I"ll remove then spring when i do skid work
thanks again
great infor here love it
TOMBOB
thanks again
TOMBOB
