STORM-CHASER
does anyone have a photo of there powermadd hands guards installed. I am trying to mount mine but I am having some clearance issuies THANKS
greenmntpass
- Jan 7, 2005
- Middlebury, Vermont
- 2000 SRX
Hey Storm I'm terrible at posting pics, but if you do a search in the apex section there are some pics. Some of which are mine. What clearence problems are you having? If you describe maybe I can help you. I didn't really have a problem with mine.
Tork
SledderSteve and others do, think they are in photo, I'll link em
in a sec
These are Apex tho http://www.ty4stroke.com/viewtopic.php?t=18369
clearance, to the windshield? Some guys have moved the brake and throttle inboard to create space if that helps
in a sec
WarriorBeads
- Dec 4, 2005
- Peterborough, Ontario, Canada
- 2004 Rx Warrior
Just installed 2 pair this weekend on 2 Warriors...Sorry no pics yet. They do touch the windy at full crank left or right....Looks like Tork's right, if you moved the throttle and branke #*$&@'ly in a bit, it would probably clear...I'm gonna wait till I get some trail miles on to see if it's really a problem.
FYI - I installed them because I found the warmers suck!....My first test with bare hands was VERY positive....I think those cold hands runnin' down the lake are a thing of the past...I was also impressed that my stock cover fits over the PowerMadds and a short left side hooker bar. Probably won't go over a 2nd bar on the right though....
STORM-CHASER
The problem I haveing if you mount them on the inside of the controls they are to short, Maybe I need to move the control and put them between the hand warmer and control. that seems to be what they did on the apex.greenmntpass said:Hey Storm I'm terrible at posting pics, but if you do a search in the apex section there are some pics. Some of which are mine. What clearence problems are you having? If you describe maybe I can help you. I didn't really have a problem with mine.
RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
monker
putting them on the inside of the controls I could not get them moved out enough to miss the widshield. I ended up mounting them betweend the controls and hand grip. I have had no problem with them there. If you want a pic of how I have them setup I can get one this weekend.
4Fighter
- Oct 28, 2003
- Sault, MI
- '07 Attak GT
monker said:putting them on the inside of the controls I could not get them moved out enough to miss the widshield. I ended up mounting them betweend the controls and hand grip. I have had no problem with them there. If you want a pic of how I have them setup I can get one this weekend.
I'd definitely like to see some pics.
greenmntpass
- Jan 7, 2005
- 2000 SRX
You definately want to loosen brake and throttle assy. and slide them in and mount them to the outside. This should give you more clearence pushing the guards out. Also on the mounting there are two holes, one about 3/8" away from the other. These holes are what the guards mount on. Mount the guards in the closest hole to the handlbars. This will give you an extra 3/8" clr. You will have to rotate the guard bracket to clear the brake lever. Hope this helps.
STORM-CHASER
This helps I was trying to do it on the inside, Now this should work thanksgreenmntpass said:You definately want to loosen brake and throttle assy. and slide them in and mount them to the outside. This should give you more clearence pushing the guards out. Also on the mounting there are two holes, one about 3/8" away from the other. These holes are what the guards mount on. Mount the guards in the closest hole to the handlbars. This will give you an extra 3/8" clr. You will have to rotate the guard bracket to clear the brake lever. Hope this helps.
yamaslob
Im goin be putten some chrome powermadd's on my nytro taken the yellow off and spray painten them to go on the RTX.
