Z06 FAN
- Nov 21, 2014
- 06 Apex's GT/RTX
I purchased two 2006 apexes this year and went to plug in a gps and the 12 volt jack don't work on both machines. Where is the fuse? Is there something im missing maybe?
Take off the hood and right side panel fuse is above the chaincase on the alum. bar. The fuse block is small and the fuse is the SIG fuse.
Z06 FAN
- Nov 21, 2014
- 06 Apex's GT/RTX
Well the fuses are good on both machines. The gps will work in my truck but not on both sleds. Am I overlooking something for both machines to not work??
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Stupid question... Is the sled running?
Make sure the plug has power after plugged in... at the GPS end.Well the fuses are good on both machines. The gps will work in my truck but not on both sleds. Am I overlooking something for both machines to not work??
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
Not a stupid question. The right question.
x2 Riceburner
Z06 FAN
- Nov 21, 2014
- 06 Apex's GT/RTX
Yes I have tried it with the sleds running and both don't work.
Contact Rockmiester...
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
How well does the adaptor fit in the socket? Loose fitting may not be making a connection.
Is the GPS manufacturer's recommended adaptor?
Does any other item that can plug into the socket power up? ie, phone charger, air compressor, etc.
Are the sockets on the sleds actually connected to the sled? Sometimes, when I remove that dash panel, I disconnect wiring to make it easier.
