STINKFINGER
some of my friends ride rx-1 and one rides an srx. they have the most powerful headlights . due the 06's follow suit?
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
I noticed no fall off from my Warrior or RX-1 which were the best
gamer1
- Mar 14, 2005
Not sure how the headlight power is compared to previous years but I can gurantee theres not a sled better for hunting racoons on high beam than my RTX.
My RX1 is not good at all - on low it points too far down, if you aim it correctly, then when you put the high beams on they are way up in the trees.
yamaslob
gamer 1 said:Not sure how the headlight power is compared to previous years but I can gurantee theres not a sled better for hunting racoons on high beam than my RTX.
haha
canadianhunter
The high/ low beams are a set thing in the bulb. Not sure if different manufactures would be different.
The only other thing that may increase or decrease the diff. between high/low would be how far the bulb is mounted into the assembly [refecter system]. One could try a very thin washer ahead of the bulb flange - not sure which way the diff. will be, but may be worth a try.
Haven't had a chance to see if the Rage has this problem.
