Daranello
Suspended
Going to stud my Attak with ethier 108 double backers or 108 Single backers.
I used 102 on my F7 and I was very happy and to me was a great ballence. I do allot of WOT so I don't want the extre weight of studs
YamaMikeRTX
i'm going with double, had a couple of singles tear through last year
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
I'd go with doubles as well, better stud support and less pull throughs
vmaxx05stud
theres like a 196 singles on my track w/ 1300 miles w/ no problems except a couple of bent ones.
yamaouch08
- Jan 17, 2006
- Otisville,Michigan
- www.chapmanssports.com
I would go with the doubles. IMO they are stronger
ROCKRTX
Double backers here too.
DoktorC
96 double backers...love it!
nate007
- Dec 25, 2006
- Iowa City, Iowa
- 1. '06 Apex -twin screw
2. '04 Redline Revolt 800
3. '09 Nytro XTX - twin screw
I have a combination of singles and doubles. Seems to work very well. After about 800 miles on them last season, I have no bent or broken ones.
I used Woody's Signature Series, with alum. backers
justinator
- Mar 25, 2007
- Maine
I think that maybe by the time this topic has ended you'll see that many have had good luck with both. Many like the support of the doubles, in case of that hidden object under the snow you had no idea was there.
snoman
with 1.25's or 1.375's ?
REDSLED1
I have been using double fastrac angle backers for years and have great luck with them. I took one and drilled it out so my cutting tool would go through the hole, then i placed it where i wanted it, against the lug snugly then drilled the two holes. I just done the middle and kept them about one inch from the centre. I use 1.4 megabites and put a washer over the stud then the nut, it doesn't dig into the backer and can be removed easily.
mulderdad
Nate.
Do you have any pics of the pattern you have?
I have 96 singles now and am gonna add about 24 doubles. Looking to run 144 or so mixed singles/dbls 1.40 ss.
Thanks,
Rick.
Thanks,
Rick.
TurboTime
- Jan 3, 2006
- Cassopolis, MI
- 2009 Yanaha Nytro
snoman said:with 1.25's or 1.375's ?
1.325 woodys
sleddheadd
i just put 108 doubles on my warrior. doubles were highly suggested from rich , so thats what i went with! i threw way to many singles out last year so i was open for sugestions!
Daranello
Suspended
where the best place to buy the studs?
