drag'n'fly setup
2.5 tip + long bolt/2 washers
3.2 mid + 1 washer
Arm- 1 bolt 1lock/2washers
Red or black spring primary, 14.5 rollers
stock secondary 70 degree wrap 1-6 I believe.
stock gearing
1 3/4 backcountry
full excell with airbox mod, RB3
Found it.
go to Harbor Freight and buy a gram scale for $10.
Nuts and bolts can vary in weight depending on size. With a scale you can go to the hardware store and buy the weights you need. I use bolts that are 1.3 and 3.3 grams and nuts that are 1.3 grams. I also have washers that are between .1-.4 grams for finer tuning.
