Peterbilt95
- Jan 30, 2015
- Apex
can anyone tell me how to drain the oil in the chain case I don't see a drain plug in My 2011 apex
sideshowBob
Behind the lower part of the chaincase, inside the tunnel, there is a 12mm head bolt with a copper gasket. Access it on track side of tunnel.
Remove that bolt and the oil will drain.
Peterbilt95
- Jan 30, 2015
- Apex
Thanks very much
Hartatac
- Aug 25, 2014
- New Brunswick
- Yamaha Apex GT
- New Brunswick
When you remove the plug make sure the rubber seal is still on it. It will still plug the hole when screwed on without the seal but I had one back off before.
