draining and filling coolant
yzf1999
Bloomington, Illinois
2015 Yamaha SR Viper LTX SE
What is the best way to drain and fill the coolant? I want to mix a 50/50 blend of engine ice and anti-freeze. You have too bleed the system of air pockets right? Any suggestions would be appreciated.
Yeah, I think you are thinking of Water Wetter. Another product at reducing temps. If I recall water wetter in mixed with antifreeze and engine ice is used as is.
yzf1999 said:
Yeah thats right, I meant water wetter and antifreeze..so how do I do it?
when i drained my coolant, i disconnected the hose from the bottom of the radiator, took out a gal. and re-placed with a combo of 50/50 with 1/2 a bottle of water wetter, there is a bleeder, to get the air out, make sure you get all the air out, you have to pick the machine up from the front and back, then check it
