FoxFire227
- Nov 24, 2019
- Ottawa
- 2014 Viper LTX SE / MCX190
Happy Wednesday!
Couple issues I'm having with my 2014 Viper LTX SE - MCX190
1) Always need to carry a booster pack when riding - sometimes it starts, sometimes it doesn't.
2) Sled wont start at all. I turn the key and it clicks at the starter relay solenoid near the battery. Bought a new relay and it doesn't even do anything. Battery is good.
3) ECU has been flashed - Do i need a new starter? Is there more damage?
It's literally always an issue when starting this sled. I have zero faith that I can go for a ride, shut it off then have it re-start without any issue. There HAS to be an actual fix for this?
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
Is your starter original?
Many of these starters had the magnets break and cause the starter to drag and eventually fail.
If your starter is original to the machine it may be time to remove, inspect and possibly replace it.
Vipermax59
- Oct 14, 2024
- Rochester, mi
- 2014 Yamaha SR Viper
I also have a starting issue with 2014 SR Viper.
I always start and run this sled every month during the off season.
Last try it produced a loud pop and now it wont even crank.
I turn the key now and it just buzzes and chirps, no attempt to crank.
Also no error codes on the display.
I did replace the starter relay block on top of the battery
but no change.
Desperate to know if anyone else has experienced this problem
and what the solution may be.
Only 2,100 miles on the sled!
Desperate for any help.
but no change.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
Engine kicked back ruining starter
Vipermax59
- Oct 14, 2024
- Rochester, mi
Thanks,
What caused the engine to kick back?
Any tricks or tips to replacing the starter?
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
Flooded or fouled plugs. If your starting every month you need to run till at operating temp or plugs will get fouled and cause issues. Also they hate stale fuel. I would inspect for a damaged starter and also check the gear that the starter meshes with for damaged or broken teeth.
